Galvanized condensate recievers? Yes/No?
Jim_2
Member Posts: 3
What are your thoughts on galvanized (hot dipped) condensate recievers?
I have herd aggresive condensate can cause pinholes in the coating, causing it to peel off. Any coating that peels off will be a problem for the pump impeller.
JTM
JTM
I've never
seen the need for galvanized.Retired and loving it.0 -
Gal tank
Took one out after 15 years of service due to leaking,cut it apart just to see. Found above water line like new,below water line was like pulling a boat out of the water after 15 yrs things were living in there,looked like the surface of the moon but brown instead of green.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
