Remotely operated thermostats
chuck shaw
Member Posts: 584
I have a coustomer, with a home on Cape Cod, he lives in Boston. He has his home maintain 50*F when he is away. He has a system, that allows him to toggle on and off two zones of heat (6 zone system). But would like to be able to work all the zones. And have some control of the set temperature. He usually would do this the night before he came down, or the morning he came down. Has anyone had good luck with a system such as this? What brands have you used? Pros and Cons? Any information would be great
thanks in advance
Chuck Shaw
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
thanks in advance
Chuck Shaw
Networked zoning system
Hi, Chuck! Check out our Networked zoning system. It works with hydronics and offeres access from any touchtone phone, with the optional Telephone access module. Go to www.honeywell.customer.com, and follow the prompts to get the tech sheets. Good Luck!0 -
remote operation of thermostats
Research Products Corp.- Aprilaire has quite an extensive offering including software for remote control of HVAC via a modem - I'm just getting into it on a job now. Contact Dan Hansen at Aprilaire for details.0 -
thanks bill
the fax arrived today...I havent had a chance to look it over yet...but I will soon. Thanks again
Chuck Shaw
Tekmar
I do lots of weekend houses with multiple zones. I use a Tekmar house control 371. For more than 5 zones add a zone controller. Each zone can have its own occupied and unoccupied temp. A simple short between the occupied terminals switches the entire house. You can even turn the dhw off. Good Luck0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
