R-values for Stone walls
JD
JD Member Posts: 1
I do a lot of work on old stone houses and barns. (and I live in one) Using the R values from the charts, an 18 inch stone wall (stone walls in my area are consistantly about 18 inches thick) has hardly any R value. Is there an "effective" R value that takes into consideration the buffer effect of a stone wall? A stone wall holds a great deal of heat. In the day time, the sun hits the wall and absorbs the heat, warming it. What is everyone's experience with sizing systems for houses with uninsulated stone walls?
