hardwood floor on quik trak on concrete
harvey
Member Posts: 153
has anyone had any experience with quik trak over concrete?
i have lived in this house for 25 yrs, gone thru four 100 year rains and never had water seepage. the floor is four feet below grade. what do you think?
Go for it
Quick trac will work fine.There are a couple different ways to install it depending on your finished flooring.
Quick Trak Over Concrete
First you must put a layer of 5/8" or 3/4" plywood subfloor over the concrete slab. The plywood can be adhered directly to the concrete if a vapor barrier is not required. If a vapor barrier is required, then the plywood must be power nailed to the concrete slab. A high water table will affect the performance of this application. If moisture is present a vapor barrier must be used. If this is a basement or walk-out it s imperative that perimeter and edge insulation is installed.0
- 167 Indoor-Air Quality
