Below sewer laundry tub drain pump.
Chuck_7
Chuck_7 Member Posts: 71
Which is better: replace the existing pump (the suction of which is directly connected to the laundry tub drain (hung off drain)) or install a floor mount sump with a submersible pump.
  • Gary Fereday
    Gary Fereday Member Posts: 427
    Here in Utah,
    That would requier a sewage ejection system to be code approved. Sealed and vented sump, submersible pump. Because it is tied to the sanaitary sewer. other wise a garbage can and sub. pump wold do it! bigugh
  • Jackchips
    Jackchips Member Posts: 344
    Here in Mass. it is ok to have one fixture pumped directly into the sanitary without a vent. I would recommed you just replace the direct connect pump.
