Website for Trianco-Heatmaker boilers
steve_19
Member Posts: 13
I'm looking for the manufacturers phone number or website information for answers to a technical question. Specifically,the boiler operates properly when calling for heat but will not run to produce domestic hot water unless the heat ins running. Apparently the low limit aquastat is not working to maintain boiler temperature for domestic hot water. Any help is greatly appreciated
Trianco - Heatmaker parts
I'm looking for the manufacturers phone number or website information for answers to a technical question. Specifically, the boiler operates properly when calling for heat but will not run to produce domestic hot water unless the heat is running. Apparently the low limit aquastat is not working to maintain boiler temperature for domestic hot water. Any help is greatly appreciated0 -
They are owned by LAARS now a division of Teledyne/Waterpick.
Sorry......don't have the #.
Mark H
Here's the web site
http://www.laars.com
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.com0 -
Thanks for the help0 -
Heatmakers
It could be the low limit. The older ones had the submersed type can go they go bad and you have to use the strap on type. Another problem could be your mixing valve or worse case, the coil in the DHW tank could be clogged. I've cleaned them with mixed results depending on the quality of your water. You can replace the coil and i recommend it if you have a pre Mark IV verison. If you can get ahold of a service manual, it will tell you how to clean it using white vinegar. You MUST have a gas analzier to properly set the gas/air mix for combustion and a bit of knowledge. Lemme know whatcha find out.
Steve M.0 -
boiler fife
have a mod 130hwnat ser2884052 boiler stoped working changed both relay and burner cotrol, boiler only fires few sec then shuts off tryed to bypass sensores for high low nothing what could it be0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
