Whats a good , yet moderately priced oil fired heater ?
Currently we are using the Bradford White oil fired heater - for the customer who cannot afford a Bock .
We installed one yesterday . It was missing 2 of the burner flange nuts , the transition piece for the smoke pipe wouldnt fit on the top of the heater , and the sight door plug came out - in pieces . These are recurring problems . The stack temp is on the high side , and it takes quite a while to heat up .
Can anyone recommend a moderately priced heater that has is built a little better , and has more quality control ?
  • Kevin Coppinger
    Kevin Coppinger Member Posts: 29
    the only one
    I have used is john Wood. No problems.
  • keith
    keith Member Posts: 224
    Everhot
    is made in Mass. It is a good, moderatly priced,oil fired hot water heater. Good tech support as well.
  • Floyd
    Floyd Member Posts: 429
    http://www.aeroenvironmental.com/waterheaters.html
    Have taken a few of these out that were older than dirt!!!
    Have had no problems with the new ones either!!
  • John (jcg)
    John (jcg) Member Posts: 43
    Be Careful
    How you use that expression as I’m also referred to as “Dirt’s Dad” on this board.
    jcg
  • Floyd
    I will be sure to look you up....
    in Nov. If that's the case I'm sure you hold a wealth of information!!!!!
    I love to get all I can from the ones that have been around the block a time or two!!!
    Always love what I can pick up here!!!
    Remeber, though, I'm the one Murph' calls "Grampies" all the time:-)
  • hey grampies......
    if the name fits........
