Whats a good , yet moderately priced oil fired heater ?
Currently we are using the Bradford White oil fired heater - for the customer who cannot afford a Bock .
We installed one yesterday . It was missing 2 of the burner flange nuts , the transition piece for the smoke pipe wouldnt fit on the top of the heater , and the sight door plug came out - in pieces . These are recurring problems . The stack temp is on the high side , and it takes quite a while to heat up .
Can anyone recommend a moderately priced heater that has is built a little better , and has more quality control ?
the only one
I have used is john Wood. No problems.0 -
Everhot
is made in Mass. It is a good, moderatly priced,oil fired hot water heater. Good tech support as well.0 -
http://www.aeroenvironmental.com/waterheaters.html
Have taken a few of these out that were older than dirt!!!
Have had no problems with the new ones either!!0 -
Be Careful
How you use that expression as Im also referred to as Dirts Dad on this board.
jcg0 -
I will be sure to look you up....
in Nov. If that's the case I'm sure you hold a wealth of information!!!!!
I love to get all I can from the ones that have been around the block a time or two!!!
Always love what I can pick up here!!!
Remeber, though, I'm the one Murph' calls "Grampies" all the time:-)0 -
hey grampies......
if the name fits........0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
