Pex - Al - Pex, the jury is still out. (hb)
heatboy
heatboy Member Posts: 1,468
something new. After installing a couple hundred thousand feet of Pex, this is my first foray into PAP for radiant. I have used it for higher temp baseboard and like it for that use, but I'm still deciding whether to finish this project with it or go back to Pex. I like the fact that it holds corners and turnarounds well and that is easier if working alone. I just think it's very cumbersome to use and go quickly. Maybe you guys that use it often have some tips you would like to share (g). I had to coil up 6 leaders of 30' each so I could get a pressure test and it was very easily accomplished with Wirsbo's Multicor. It would have been a hassle with Pex. Pex vs. PAP hmmmm...............
Warm Regards,
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
