Open Truss Insulation
Has anyone come up with any insulation ideas for staple-up jobs without plates when using open floor trusses about 14" deep? Thanks for input.
Has anyone come up with any insulation ideas for staple-up jobs without plates when using open floor trusses about 14" deep? Thanks for input.0 -
Mike
Anytime you are insulating for a joist bay install be it suspended,plates or(yeeeeech)staple up you want your insulation R factor to be higher than what the subfloor(or floors)and finished floor is.
cheese0 -
PS............
that R factor should be two times the rfactor of the panel you are heating.Also take great care in insulating the rim joist's or box beam to stop infiltration.
cheese0 -
My concern is keeping the air space tight. Looking for a better way of insulating the space without having too large an air space.0
- 120 Geothermal
