Open Truss Insulation
Has anyone come up with any insulation ideas for staple-up jobs without plates when using open floor trusses about 14" deep? Thanks for input.
Has anyone come up with any insulation ideas for staple-up jobs without plates when using open floor trusses about 14" deep? Thanks for input.0 -
Mike
Anytime you are insulating for a joist bay install be it suspended,plates or(yeeeeech)staple up you want your insulation R factor to be higher than what the subfloor(or floors)and finished floor is.
cheese0 -
PS............
that R factor should be two times the rfactor of the panel you are heating.Also take great care in insulating the rim joist's or box beam to stop infiltration.
cheese0 -
My concern is keeping the air space tight. Looking for a better way of insulating the space without having too large an air space.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
