Hot water /Boiler Combo
I am in the process of starting a project where the building owner would like each apartment to produce their own domestic hot water and hydronic heat. We want to keep the units in each apartment and use direct vent models. Any recommmendations from your expierences with manufacturers?
Laars Endurance(nm)
Self contained Boilers/DHW
Mike,
If your project is gas, then consider the Burnham Minuteman boiler. It fits in most tight places with minimal clearances, is direct vented and has it's own built-in DHW. They use simple controls and the boiler is cast iron. Take a look at the link below. Hope this helps!
Glenn Stanton
Burnham Corp.0 -
Mike,
Glenn Stanton
Burnham Corp.
http://www.burnham.com/residential/51160.cfm0 -
Quietside
We have used several Quietside combo boiler/DHW with excellent success...wall-mounted, 90+% efficient. Check out their website, www.quietside.com.0 -
Phase III / Triangle Tube
Has two direct-fired combo configurations. I had posted an inquiry on the Wall a couple weeks ago asking about experiences and had a few responses - mostly favorable. No personal experience yet.
Best Regards
DZ0 -
take a look...
at the Viessmann Vitodens. This boiler is a sealed combustion, direct vent wall mounted condensing boiler. The smallest one, the Combi, has a built in flat plate to produce DHW. Perfect for appartments.
kf0 -
Glenn
Do you make the Minuteman with a regular vent ? We use the Peerless 61 series Gas boiler with the coil for tight spaces , but the boiler is very bulky .0 -
I agree with the Veissmann.....
The Vitodens is great @ 200#'s of high grade stainless steel, but they can't be holding onto their wallets too tight. But because of the easy install on the smaller one with the builtin dhw heat exchanger, they may not end up costing much more.
Steve0 -
Monitor MZ has best history
and has easiest installation. the MZ 25S is a combi unit that is fully condensing (95% effic.) and a 22 year history of success. I own and have installed many of these. Check out the link www.mzboiler.com
Matt0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
