LOW MASS OIL FIRED BOILERS
Eric
Eric Member Posts: 95
Any manufacturers of low mass oil fired boilers.
Somewhere around 300,000 to 800,000 water net IBR.
Looked at Laars any others?
  • heatboy
    heatboy Member Posts: 1,468
    Why...........
    would you even consider such a thing? Low mass, high input, non-modulating, oil heating equipment? Makes me nervous just saying it (g).
    hb
  • kevin
    kevin Member Posts: 420
    try
    Pensotti Boilers Low water content Easy to clean, CI, Italian design..
    www.pensotti-pna.com
    Kevin C.
  • Vernon P. James
    Vernon P. James Member Posts: 42
    cast iron low mass boiler
    Take a look at Crown F series scotch marine cast iron line it might be of interest.
  • heatboy
    I agree!
    The FW series from Crown is a very good boiler line. While they have a lower water content than most, I would not consider the FW-4 (355MBH) @ 950 lbs. or the FW-8 (907MBH) @ 1650 lbs. "low mass".
    If the budget will allow, look at the Viessmann Rondomat series. It has things like a computerized shunt pump for boiler protection and a full array of custom controls available. It really gets no better than Rondomat when it comes to big oil-fired equipment.
    Warm Regards,
    hb
    www.climatecadvanced.com
