LOW MASS OIL FIRED BOILERS
Eric
Member Posts: 95
Any manufacturers of low mass oil fired boilers.
Somewhere around 300,000 to 800,000 water net IBR.
Looked at Laars any others?
Why...........
would you even consider such a thing? Low mass, high input, non-modulating, oil heating equipment? Makes me nervous just saying it (g).
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
try
Pensotti Boilers Low water content Easy to clean, CI, Italian design..
www.pensotti-pna.com
Kevin C.0 -
cast iron low mass boiler
Take a look at Crown F series scotch marine cast iron line it might be of interest.0 -
I agree!
The FW series from Crown is a very good boiler line. While they have a lower water content than most, I would not consider the FW-4 (355MBH) @ 950 lbs. or the FW-8 (907MBH) @ 1650 lbs. "low mass".
If the budget will allow, look at the Viessmann Rondomat series. It has things like a computerized shunt pump for boiler protection and a full array of custom controls available. It really gets no better than Rondomat when it comes to big oil-fired equipment.
Warm Regards,
hb
www.climatecadvanced.com
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
