Compression Tank
Eddy
Member Posts: 21
I would like to replace the existing compression tank on a heating water system for a 2 story structure. It has a sight glass that always leaks, loses it's charge frequently and is a pain to get air into. I plan on replacing it with a "blaadder" style tank. How do I size one of those? Can I just replace it with the same size that's there now?
Compression tank?
Go to amtrol.com and get their ideas for the proper tank. (The bladder tank will be much smaller)
Good luck!0
- 167 Indoor-Air Quality
