Compression Tank
Eddy
Eddy Member Posts: 21
I would like to replace the existing compression tank on a heating water system for a 2 story structure. It has a sight glass that always leaks, loses it's charge frequently and is a pain to get air into. I plan on replacing it with a "blaadder" style tank. How do I size one of those? Can I just replace it with the same size that's there now?
  • Gary Fereday
    Gary Fereday Member Posts: 427
    Compression tank?
    Go to amtrol.com and get their ideas for the proper tank. (The bladder tank will be much smaller)
    Good luck!
