Hate to sound like a pest but need to know about PEX
kevin
Member Posts: 420
Using PEX tubing
Need some opinions on using PEX tubing for both heating zones and domestic hot water. First can it be used for domestic hot water? Second should I have any concerns about using PEX instead of copper for my 5 zone heating system (one zone is for the indirect hwh 3 for baseboard loops 1 for fan coil in garage). I am installing a new system and moving the boiler from laundry room to garage(Buderus direct vent). Does anyone know if PEX has a web page that can help? Thanks for your help in the past.0 -
Hot Tech Topics
Look for "Pex Choices" and Oxygen diffusion corrosion" in hot tech topics in this great site. Consider buying one or more of Dan's books.
DZ0 -
Pex
We use pex tubing for hot and cold water as well as heatloops.The near boiler piping is still copper as it looks and works better,but once were in the joists or under the floor it's all pex.
Check out one of the manufactureres that sell pex web sites.Some of the common brands are Wirsbo,RTI,Stadler.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
