A valve for the injection bridge
hr
Member Posts: 6,106
Siggy showed me one of these recently. You set the GPM and read it in the window. A simple accurate way to set the injection flow. This one is from the Watts Radiant catalog. www.istec-corp.com has them also.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
REHAU has been selling them for many years now. They have 4 pages of this stuff in their catalog.0 -
Is that a differential pressure by-pass valve?
Thanks, Ant
Here is a PAB
pressure activated bypass, alsocalled a differential by pass valve. It is a valve that opens progressively as the pressure in a circuit increases. In multi zone valved system for example as the zone valves start closing it allow a portion of the flow to bypass.
The flow setting valve in the first post allows you to set one fixed flow. Useful on a circuit where you need an exact GPM flow, as in injection mixing.
hot rod
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
