DHW heater/ radiant seperation
Hey Hotrod,
I built this one to isolate the antifreeze mixture for a backup power generator. The generator needed to maintain 115 deg. all year long.The primary side runs off of an indirrect DHW heater.
Look how proud it's Papa looks.
G.man
G.man
At first
look the money for this nicely built HX module looks prohibitive.
Crunch the numbers my fellow heads of wet
I mounted, piped, filled and ran this system two hours after driving up to the job. The radiant tube had been previously installed in the small 225 square foot kitchen remodel.
Pretty darn good bang for the bucks when using a current WH and wanting piece of mind from the combined DHW/ radiant system risk and liabilty potential. Bet I couldn't buy 8 hours of attorney time for the cost of this isolation panel.
This Danfoss ZCP even had a nifty little reset/ setpoint control on the HX!
hot rodBob "hot rod" Rohr
Yeah
You can't beat a water heater for doing double duty on those small radiant jobs. And that Danfoss ZCP does such a nice job in such a small box.
Nice work, hr.
A closer look
Danfoss also makes a nice isolation panel.
This kept me buissy for about 5-6 hours.
Makes more sense to buy them out of the box.
G.man0 -
Nice work Gary
I like the pretty colors too. I've built my own on site, but must admit they didn't look as nice as yours or Danfosses for that matter. A previous post was asking what he could do with his down time. You should have him make panels for you. :)WW
It's a great idea
I went to a Danfoss training seminar last month. Great stuff although I do struggle with the cost. My Scottish heritage keeps me tight. I've built many heat exchanger panels on site to get dual use from water heaters, but it is a definite time burner. You come out of the basement and scratch your head and say how did it get so dark out??? I've got a price book from Danfoss but my local supplier can't seem to get me a multiplier. (I bet if I did as much purchasing and Foley Mechanical they'd respond more better.)
I'll bet.......
once you plug in labor and equipment numbers, you won't be too far off from the cost of the ZCP. Huge labor savings with the ZCP. I will admit, if you have the time to make the panel yourself, you can put more money in your pocket. It all comes down to time management. At my business costs, I can't make a panel this nice for the money I spend buying this particular ZCP.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
I guess an old
dog can teach new tricks (just kidding). I have a perfect application for this particular ZCP panel...thanks!
Michael Bleier
Able Distributors
www.abledistributors.com
"The Supplier Who Works With You"0 -
Danfoss panel VS homemade
Yeah Heatboy, but they do not make diamondplated ones. I've seen some of your control panels. More like multimedia sculpture than plumbing. Nice work.
Nice website too.
Is everything you do that neat?
G.man0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
