Steam question for Dan
that one of our serviceman had a question about , and stopped the whole " You and Me In The Basement " mini seminar a few weeks ago . This is what was there orginally , I believe it was a Burnham ?
We used a Peerless ECT 4
to replace it . We used the 2 header tappings and twinned them into a 3 inch header , and ran each main into it individually .0 -
Dont mind Kenny
He always does this right when I'm taking the pic . This shows where we placed the main vent on the dry return - above Kenny's head .
The serviceman , John , said he went back to this job a few months later and found that the main that is connected to the pipe with the dry return , and all the rads on that main , filled with water . He wanted to know how this can happen . The whole house was a hodgepodge of radiation - some regular sectionals , some 1 1/4 fin tube baseboard , and some regular 3/4 baseboard upstairs , and one bathroom had just a 2 inch riser with a vent in the middle of it . We replaced about 4 vents on some of the rads when we installed the boiler . We were going to try to replace the vent on the other main that had a wet return , but it was buried in a wall . Any ideas ? Thanks guys .0 -
That Peerless
does a nice job of producing steam. Nice looking.
David0 -
Buried Main Vent
Ron, we usually install some sort of access hatch where a main vent is buried. Many times a small, thin piece of plywood works well, or you can get prefabricated units from suppliers. This preserves access to the vent so we can get at it if needed.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Yes , I like them too
I worked in NYC for about 10 years installing Peerless steam almost exclusively , and in that time we probably had to replace a handful of the old JOT line . They make a very tough , forgiving boiler . Thank you David .0 -
When he went back
John told the homeowner to open up the wall so he could change the buried vent . Before that , you could just make out where it was - someone tapped a 2 inch ell and used a 1/8 inch nipple and it looked like a regular radiator vent . I'm not sure what John did about that vent , but the problem side of the system was on the main with the dry return and the main vent I added at the boiler . My best guess is that one of the rad vents was open for steam and got stuck closed somehow , trapping condensate in the rad and the main with vacuum . But John said the rads and dry return were totally filled with water . I remember looking at the main , and it did have a good pitch down back to the return .0 -
Nice piping job
