HELP! on radiant add on to existing zone
hr
hr Member Posts: 6,106
Can be found at this link. Copy and paste it into you search window.
www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,62497,00.html
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • ed
    ed Member Posts: 4
    RADIANT ZONE
    want to add dining room radiant heat off existing base board heat. all existing zones haver zone valves, how do i pipe mixing valve to existing zone. thanks in advance diagram would be helpfull
  • here's one way
    This uses an existing zone and adds the floor loop to it. However you do it involves putting a pump in after the mixing valve, to provide the force needed on both sides of the mixing valve inlet.
