HELP! on radiant add on to existing zone
hr
hr Member Posts: 6,106
Can be found at this link. Copy and paste it into you search window.
www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,62497,00.html
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • ed
    ed Member Posts: 4
    RADIANT ZONE
    want to add dining room radiant heat off existing base board heat. all existing zones haver zone valves, how do i pipe mixing valve to existing zone. thanks in advance diagram would be helpfull
  • here's one way
    This uses an existing zone and adds the floor loop to it. However you do it involves putting a pump in after the mixing valve, to provide the force needed on both sides of the mixing valve inlet.
Welcome
It looks like you're new here. Sign in or register to get started.
