AC question
Steve Ebels
Member Posts: 904
I've done a heat loss/gain for a church building I'm working on using HVAC-CALC. The numbers look good, however, the program doesn't include any factors for people, as in live bodies as far as heat gain is concerned. What btu load should I take into account per person. Or, put another way, what's the btu output of your standard run of the mill human be'an
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=175&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
A.C.SIZING
WAS ALWAYS TOLD ABOUT 300 BTU'S PER BODY.0 -
People are most of the load
From my old mechanical engineering text, seated at rest 350 btu/hr per person (ie. movie theatre); standing light work, 640btu/hr; dancing,1280 btu/hr. I think you are going to need to find what type of worship style that is used. Also, not sure if the program you are using accounts for length of time of occupancy, or the mass of the structure or furnishings. For most churches these have a huge impact on the calculated load. I calulated my own church sanctuary, 1850's 20 inch stone walls, R-38 ceiling about 16 feet high on average, 10 inch reinforced concrete floor, not too much window area, seating capacity about 280 and ended up with only 6 tons load due to the short occupancy and high mass of the structure. 3- 2 ton Carrier ductless split systems were installed. Really nice dehumidification, no duct losses and no holes in the ancient plaster ceiling. I don't do A/C instalation, but have worked with several churches that use ductless units and all have been quite pleased. I recommend a good contractor I partner with for doing installs. Hope this helps!
Boilerpro0 -
AC question
WHOOPS!
Sorry for the ditto.
A difference
Hey Steve, are they prayin' or singin'? Gotta make a difference I believe.0 -
people load
sensible & latent0 -
I like that, J
Where did you get it.
Brian in hot, sticky, humid, swampland, where the revival-type churches need wayyyyyyy more air conditioning than your average place of worship.0 -
Hvac-calc
Steve, Hvac-calc has it set up for 300 senible and 230latent
as set out in manual j. If i may add if you could drop your rh to about 50% this will give you a little more latent load
This seen to help when it dance time and everyone start to sweat, it does not take much water vapor to get the whole
place feelin muggy again.the last church we did we went with vs equipment with humidistat seen to help with the ladies when there hormone got to there peak and they forgot the estrogen. Don0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
