Thermo Pride furnace (Starch)
Starch
Member Posts: 102
My sister-in-law needs a new furnace (too far away for me!) A local contractor has quoted her a Thermo Pride 90+ unit.
I have never seen one of these. Any opinions - good, bad, ugly?
Thanks,
Starch
Thanks,
Starch
thermo pride
Very nice unit, well built not tin e, good support.
Has rounded corners looks like from the 50's.
Co. is owned by Burnham I think Hope this helps0 -
Thermopride
Havn't had any experience with the +90 furnace but I have installed several oil fired Thermoprides. They are a great unit as far has warm air is concerned. Lifetime on the heat exchanger, you can tell they are a solid unit when you carry them in the house. They are owned by Burnham for the last 3 or 4 years.0 -
Thanks, guys!
Anything associated with Burnham is good enough for me, then!
Starch0 -
Thermo Pride Furnaces
Check out the website @ thermopride.com. There is a lot of information available there including I&O manuals.0 -
Built like a tank
a higher end furnace, made in I think N. Judson Indiana, bought by Burnham a few years ago. The tube heat exchanger had the thickest walls of any I've seen. They made a low boy model, not sure if they still do. Nice WA furnace.0 -
Thermopride
I've put in several of the 90% gas units over the last couple years. Really good equipment. Had two control boards fail, one was DOA and the other after about 2 days. No other problems of any kind. Thermopride said they had a run of boards from W/R that were bad and they haven't had any since. GOOD STUFF!!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
