Vitodens Project- Mike Norgan
Mike Norgan
Member Posts: 24
Here are some updated pictures of our latest project using the new Vitodens. I'm heating the pool and some radiant around the pool.
Mike Norgan
Mike Norgan
Nice work Mike
What is the concept of the "black box". Called a low something header? Thanks
hot rod
HR,
The low-loss header is used to decouple high flow rate systems from the boiler loop.0 -
Hey Mike
Good to see you are staying out of trouble. Is that system fired up yet? We lit off our first Vitodens a couple weeks ago. The HO asked about 5 times if we were sure it was running and hardly believed me until I had him grab the piping and see that it was getting warm. They are unlike anything I've ever installed before. Just hang it, vent it, pipe it and plug it in. Took about 3 hours total.
Keep us posted on that job you have going there.
Have you
used the neutralizer setup?
We have
installed this little beauty and it is up and running. We have had lots of ah's from the customers on this one. Pretty much the same reaction that you had when it is firing...The pictures look amazing, keep up the good work.
Michael0 -
HR: basically as I understand it in effect your creating a kind of primary/secondary loop within the box.but ihaven't done one myself yet
The low loss
header allows output up to 230 k Btu per hour (250 in on the biggest unit) but limits the flow throught the heat exchanger to 15 gpm. The Vitodens 200 has the ability to use temperature drop across the heat exchanger and mix those BTU's into the flow going through the low loss header. Granted this is simplified, but when one utilizes this type of heat exchanger, overflowing will reduce the capability. The Vitodens is capable of condensing AND continues modulation of temperature. So...reset through the boiler is possible, energy is saved by condensing, temperature matching, cycling is eliminated and the boiler needs no protection. Since it is utilizing the standard Viessmann m.o., the control fundamentals (plug and play, numbered plugs, pump module) are all the same, learning an entirely new control set up is not necessary. In a nutshell: Hang it - pipe it - plug it - run it.0 -
Damn, Mike...
you always sell the FIRST machine! Please let me know how she works, as I am not confident with my local people.
One distributor isn't impressed enough to stock the machine, and the other won't invite me to training seminars!
You are very lucky to have a quality rep and distributor that can provide the whole package!
Keep sailing, my friend,
Mi39ke
Space
Do you need to take all that wall space?
AL0 -
good timing
I was just looking at the Vitodens. The pictures were very helpful. Also looked it over in Cincinnati at REX. Thanks for posting this job.
Nice work.0 -
space
The space that I used isn't really that much, I piped over to the pool equiptment, so the HX was a little closer to my conections.0 -
Updated pictures of our project.
Here are more picture of this project.0 -
8-02-02 updated pictures
We just poured the gyp-crete yesterday.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
