Pex & Foam - DZ
Dana Zaichkin_2
Member Posts: 36
While It's commonly used, I've always wondered about the effect of sealant foam on some of our more chamically sensitive plastics - namely Pex & ABS. Perhaps Rohr laboratories has conducted some bench tests? :-)
If you don't use foam, what is your preferred fire/draft stop product?
Thanks & Best Regards
Dana
Dana
\"Rorh Labs\"
I like that!!0 -
I tried walking that road once
I contacted 3 manufactures for an idea of what is safe against pex. The only ONE product all agreed was "probably" safe was silicone.
I suspect you would need to know the exact ingrediants of a proposed product to get an official nod on pex compatability.
Sounds like a good project for you'all
hot rod
Yep - Silicone
Looking through the handy dandy Aquapex instal booklet there's discussion of their silicone product but no mention of foam - neither "do" nor "don't".
HR - I figured that you would have at least some info to share - Thanks!!
Best Regards
Dana0 -
Pex and chemicals
If memory serves me correctly, Mr Barba told me that the only common chemical that affects Wirsbo tube is xylene...and it has to be boiling! Someone please correct me if I'm in error. Kevin.0 -
Firestop
Ipex/Kitec recommend (actually have had UL certify) 3M Firebarrier 2000+ and Firebarrier CP25WB+ as the product to use, in conjunction with mineral wool, for horizontal and vertical firestop.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
