what type of 608 certifcation do you need
Joe Grosso
Joe Grosso Member Posts: 307
What type 608 do you need for ac work 1,2,3 or universal?
  • ChrisL
    ChrisL Member Posts: 121
    Certification
    It all depends on what type of Ac systems you want to work on. Go to www.epatest.com to read info on the differences between 608 certifications.
    Chris
  • Heatermon
    Heatermon Member Posts: 119
    608 universal certification
    will allow you to work on all a.c., except automobile, which requires 609 certification. If you pass the core section and any one of the three types (1,2, and 3) you will be able to perform work in that section. Section 1 is for small appliances (5 pounds or less of refrigerent). Section 2 is for high pressure systems and section 3 is for low pressure systems.
    Good luck,
    Heatermon
  • Joe Grosso
    heatermon
    Are residential systems 5 pounds or less?
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Lbs.
    Once you get over 2- 2 1/2 tons you're usually over 5#'s. Some units even in that size range are over that amount.
  • Larry_7
    Larry_7 Member Posts: 86
    Type 2
    I don't have the literature in front of me but I think type two would cover the split system used in residential. Type 1 is small appliances and further states the entire unit is hermetically sealed at the factory. ie window units, refrigerators, package terminal heat pumps. A split system isn't hermetically sealed due to the required line and indoor coil connections.
    Larry
