loosening a steam radiator
Is there an easy way to loosen a steam rad from the inlet valve. Mine is really stuck and I want to move it away from the wall in order to clean it and paint it?
24" to 36" pipe wrench if that dosen't work I would cut off with sawall and replace steam valve. PS Sometimes if rad. is to high on one end remove shims to relieve pressure on union which could also help!0 -
loosening rad union
Pipe wrenches collapse around a pipe to grip it. Loosen your pipe wrench to the point that it just grips the union hub. then try it. Many times the tightly adjusted wrench will collapse the hub to the point that they will not loosen. Good luck! bigugh0 -
If you have the space
Try loosening the union by tapping it on all sides with a hammer . Not too hard , or you might break the fitting off in the radiator . We do it all the time on steam unions around the near boiler piping.0
- 123 Chimneys & Flues
