Hy Vents
kevin
kevin Member Posts: 420
What are you guys using for air scoop/ boiler hy vents. I have used both sparco and Taco. I have not had very good luck with either. After a few months many will start to leak out of the cap on top. I have tried to clean them out but no luck, same problem...and i end up replacing the whole thing.I have stared to use the shutoffs that Legend makes but that only makes replacement easier not ,eliminatied.What do you think? Thanks, Kevin C.
