Under Heat
Wayne
Wayne Member Posts: 4
I am looking to buy a house that has "Under Heat and Air".
Does this mean Radiant?
  • John@Reliable
    John@Reliable Member Posts: 379
    This could mean alot of things to different people maybe unit is under the house in crawl space? who knows.Good luck & would look for yourself.
  • Big Ed
    Big Ed Member Posts: 1,117
    Maybe \"Counter Flow Furnace\"?
    Never heard of a "under heat and air" could be a counter flow furnace . This is a furnace that forces hot air down into the floor ductwork and out into each of the rooms . A ok system for a small ranch or trailer but stinks if used in a house with a second story. The top floor will not get enough heat for comfort......
  • Wayne
    Thank You
    Thank you for the responses. I will look myself to be sure. Wayne
