Under Heat
Wayne
Member Posts: 4
I am looking to buy a house that has "Under Heat and Air".
Does this mean Radiant?
This could mean alot of things to different people maybe unit is under the house in crawl space? who knows.Good luck & would look for yourself.0 -
Maybe \"Counter Flow Furnace\"?
Never heard of a "under heat and air" could be a counter flow furnace . This is a furnace that forces hot air down into the floor ductwork and out into each of the rooms . A ok system for a small ranch or trailer but stinks if used in a house with a second story. The top floor will not get enough heat for comfort......0 -
Thank You
Thank you for the responses. I will look myself to be sure. Wayne0
