hot water radiator valves
tommy
tommy Member Posts: 2
what is the reason for the pin hole in hot water
radiator valves?
thanks tommy
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Pin-hole in valve
    To keep a touch of flow even when closed to make freeze-ups less likely.
  • Boilerpro
    Boilerpro Member Posts: 410
    However, that pin hole was sized for gravity systems...
    Put a pump on it and it can become hard to control the heat output of the rad.....there is no off position.
    Biolerpro
