Experiance with Polaris combo unit. - zimm
Bryan
Member Posts: 3
I have a customer who has been surfing the web and
came across the radiantdirect page.
They are asking me what I know about the Polaris Combo
unit and there products they promote.
Anyone have any experience with this unit and system.
Thanks Zimm
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=220&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks Zimm
Polaris
the Polaris is a gas fired water heater manufactured by the American Water Heater Company. It is a sealed combustion 92% efficient, condensing water heater with a stainless steel tank. IT Vents with PVC and has side tappings for a heating. It only has one tank so the domestic water and the heating water are the same. Must use all copper piping with bronze pumps. Check your local codes, some states won't allow it to be used with baseboard or radiant only fancoil units. The few that we have sold are running fine.
kf0 -
Unless you want PAH's
voice in the back of your mind forever!!, I'd suggest seperating the DHW from the heat. I agree it probably a safer install. Those combined systems may haunt us someday! With or with Daves helpEven though Lennox and Appollo sell lots of Complete heat systems with combined DHW/ heat. I understand the Lennox Complete heat has a pump exercise cycle every day to stir the system.
Here is how I set up my Polaris DHW/ radiant. A small flat plate HX with a bronze pump. This pump could also serve as a DHW recirc pump wit some extra tappings and flow adjusting valves.
This is a nice hi efficiency system for radiant and DHW. This whole system is in a 36 X 36" space. Plenty of DHW with 1000.000 input.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
