If our community has helped you, please consider making a contribution to support this website.  Thanks!
Code Issue - Electrical outlets over hyd baseboard - T Ritter
                    Tim Ritter
                    Member Posts: 4
                    Gentlemen -
I have a local code official who is balking at electrical outlets installed over hydronic baseboard. He is basing his issue over the electrical code, which in some cases plainly states electrical baseboard as an issue below electrical outlets, but in some of the verbage, it just says baseboard and does not specifically state electric. I talked with Hot Rod, and he agreed that hydronic was not an issue in this case. But he also suggested that I solicit input from all of you. Have you run into anything like this before, and if so, what was your response? Any advice would be appreciated.
Thanks in advance - Tim Ritter, Springfield, MO
            Tim!
 I miss you. Nice to see your voice!Retired and loving it.0
            no problem in Chicago
 Hey Tim remember me? I am sitting here with Jimmy Dunn in McHenry and we are both laughing out loud! How our you old friend?
 To your point...to the best of our collective knowledge it has never been an issue in and around Chicago. As we all know inspectors can take these things and interpret them any way they want so you may have yourself in a little bit of a pickle. Good luck and if that doesn't help send him to Chicago for a few days...we will take care of him for you.
 Your friend,
 Michael0
            Oulet over baseboard
 Tim,
 To the best of our knowledge, there is not a code that prohibits an outlet over hot water baseboard. This does not mean that there may not be a local code, somewhere, that does so.
 Nonetheless, we would urge caution in running the wires that would be connected to that outlet. If the wire would droop into the enclosure, it probably would not be too safe with the wire on the top of the element.
 I hope this helps.
 Steve Levine
 Slant/Fin0
            code officials - my official response
 OK, so your local guy doesn't "like" seeing them installed over baseboard (hydronic or otherwise)? No problem - just produce the evidence in writing that states the violation and cites the code passage by number. If they can produce the hard evidence, I'm on board. Otherwise - take a hike. I have little patience with inspectors who attempt to enforce their personal agendas.
 To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
            Dan!
 Hi Dan! It's nice to be remembered! I miss seeing all you guys. Please drop me a line at my home email posted (I'm writing this at work). I'm still alive and kicking, working for an engineering firm. You can take the man out of hydronics, but you can't take the hydronics out of the man. Or something like that...0
            Mike!
 Hey buddy! Nice to hear from you! I will drop you a line later to catch you up on things. Tell Jimmy and the rest of the gang hello for me. I miss you guys!0
            cord over bb
 Had the same problem once. It's a bind because the inspector is right; the electrical code does say that. I wound up getting a letter from somebody at the Hydronics Institute and from a bb manufacturer saying its ok and the inspector gave me a pass. He didn't have to, though; he's just doing his job, enforcing what's clearly written in the electrical code.
 Bill0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
