Looking for info on vibration-absorbing mounting brackets- Jon H
Jon Harrod
Member Posts: 7
Can anyone recommend a system for wall-mounting circulator pumps and wall-hung boilers to minimize transmission of vibrations to an adjacent room? Thanks.
Good Vibrations
For the piping and pumps I use these "Cush Clamps" Hydro Zorbs" (brand names) type unistrut clamps.
For wall or floor mounts they have rubber/cork vibration mounting pads. Find them at Mechanical, HVAV supply houses or the Johnstone Supply catalog # R54-252 for 2" squares or R87-447 for an 18X18 sheet (precut for 2" squares) They are online at www.johnstonesupply,com.
There are also spring suspension brackets for hanging with all thread rod.
Or you could use the quietest pump available (Grundfos) and a quiet boiler
hot rod
Vibration isolation
Try the Mupro line. This German company makes the best stuff for hanging pipes or ductwork.
see: www.muprousa.com
Thanks!
Thanks Paul, J, and Hot Rod for the detailed info. This is just what I needed to get started.
BTW, the situation I'm trying to fix is a Monitor MZ and Grundfos three-speed pumps mounted against a structural insulated panel (SIP) wall. I thought 5.5" inches of polystyrene would be good sound/vibration insulation. As it turns out, the wall assembly seems to amplify the pump and inducer noise. It's pretty quiet by most standards but the customer isn't happy yet. Fortunately we're not going to have to absorb the cost of the retrofit.
Thanks again,
Jon
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
