Bend supports for pex hr
hr
Member Posts: 6,106
I prefer to use regular pex for my under floor installations. It is so easy to pull thru joists and form 8" oc loops. 3/8" Wirsbo seems to be the most flexible, from my experience.
The Pex al pex products make for a nicer looking job at manifolds and near boiler piping. I bend the short pieces of PAP with an electrical condiut bender. Using these pre- bent PAP curves give me the best of both pexes.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
Great idea!
HR,And a nice way to use up all those scrap pieces that I hate to throw out.
Hot Rod,Where do you connect
the regular pex with the pap? From your post picture it looks like near the manifold, I must be missing something because I thought a splice adapter of some type would be needed. Thanks0 -
Superglue, Dale
Actually the PAP is just a sleeve to push the regular pex thru. Works like those metal bend supports you sometime see.
hot rod
