Perpetual Circulation? - Corey Snow
corey
Member Posts: 45
Would the ideal radiant system design have the circulators running continuously?
What are the real world constraints that might make this design goal difficult, impractical, or perhaps undesirable?
Thoughts and opinions appreciated...
Constant circulation
is perhaps the best method for heat transfer. You can read about it from the German fellow who brought it to the USA. His name is Joe Friedrich and he founded Stadler. Here's a link to the articles he wrote which describe the methods.
http://www.climatepanel.com/html/contractor/contr_index.html
Constant Circulation
We set up as many systems as we can using this method. It is a system approach to radiant heat rather then banging the pumps on and off with t-stats. Outdoor reset, modulating boiler water temp, constant circulation is the European way of setting these systems up. Why mess with the best?
Michael0 -
paul
no article on constant circ on that link that i could see. i can surely see the sense of constant circ, but... it would seem that we have to hope/assume that our o.d. reset curve is right on the money, no ifs an or buts, or the place gets over or under heated... and, we had better be perfectly balanced (which is always nice) or we'll be too hot here and not enough over there?
Articles written
by Joe Friedrich can be found at the following link. The Article written February of 1996 is based on the subject of constant circulation vs. on-off control.
http://www.stadlerviega.com/html/contractor/contr_index.html0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
