Perpetual Circulation? - Corey Snow
corey
corey Member Posts: 45
Would the ideal radiant system design have the circulators running continuously?
What are the real world constraints that might make this design goal difficult, impractical, or perhaps undesirable?
Thoughts and opinions appreciated...
  • Paul Pollets_2
    Paul Pollets_2 Member Posts: 63
    Constant circulation
    is perhaps the best method for heat transfer. You can read about it from the German fellow who brought it to the USA. His name is Joe Friedrich and he founded Stadler. Here's a link to the articles he wrote which describe the methods.
    http://www.climatepanel.com/html/contractor/contr_index.html
  • Michael B
    Michael B Member Posts: 179
    Constant Circulation
    We set up as many systems as we can using this method. It is a system approach to radiant heat rather then banging the pumps on and off with t-stats. Outdoor reset, modulating boiler water temp, constant circulation is the European way of setting these systems up. Why mess with the best?
    Michael
  • rees
    rees Member Posts: 3
    paul
    no article on constant circ on that link that i could see. i can surely see the sense of constant circ, but... it would seem that we have to hope/assume that our o.d. reset curve is right on the money, no ifs an or buts, or the place gets over or under heated... and, we had better be perfectly balanced (which is always nice) or we'll be too hot here and not enough over there?
  • Andrew Granzow
    Andrew Granzow Member Posts: 1
    Articles written
    by Joe Friedrich can be found at the following link. The Article written February of 1996 is based on the subject of constant circulation vs. on-off control.
    http://www.stadlerviega.com/html/contractor/contr_index.html
