Toto Ultimate vs Ultramax - Dennis
Dennis27
Member Posts: 1
Whats the difference between the Toto Ultimate and Ultramax ? Is there a significant difference in performance ?
TOTO Ultimate vs Ultramax
Both are very fine and comparable water closets, using the high profile tank with 2 1/8" trapway and 3" flush valves. The Ultramax is the best performing water closet of the two - the technology in this unit is the best TOTO makes-and is usually rated the best available. Both have 5 year limited warranties.0 -
The UltraMax
comes with a G-Max flush system and the Ultimate comes with a power gravity system. You want the G-Max flush since it's a better flushing system.
Make sure you order the Toto soft-close seat as well. Just tip it past centerline and it will slowly lower itself back down onto the bowl. Very nice.
All the best,
Alan
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 50 Industry Classes
