ideas to empty toilet water? - Gregg Jackson
Jeff Skahill
Member Posts: 1
Some of our guys use a 2 gal wet vac, others prefer the hand pump Wolverine sells. I prefer the little wet vac its real portable and quick
ideas for pumping out toilet water?
We are starting a job that will require multiple toilet replacements. Does anybody have any good ideas for quickly evacuating the toilet water from the bowl into the tub? Any thoughts on hand pumps, electric pumps, etc?
Thanks
Gregg0 -
how about
a wet vac??0 -
I would use
the homeowner's bath towels. But make sure they are the Really good ones, you know, the big, thick, fluffy ones. After you soak up the toilet water, you can just toss them on the bedroom floor.
My High Tech Toilet Water Removel System
1. Shut off water to tank
2. Flush once
3. Take plunger insert into bowl & push until h20 gone
4. put sponge into tank(use big one)
5. wring sponge into bucket 4 to 5 times
6. m/t bucket anywhere but in toilet to avoid having to repeat step #3
**** Total time if you follow this is 2min.
**** Total cost of parts $1.99 if you have a bucket.
Hope this helps.........Good Day!0 -
TOILET WATER EVACUATOR
WOLVERINE BRASS MAKES JUST SUCH A TOOL.CALL YOUR LOCAL REP. AND YOU COULD HAVE ONE IN A DAY OR TWO.0 -
2 methods (joke-time)
1)deprive your cat of water for a day or two & leave the bowl cover open
2)lie down next to the toilet, put one end of a garden hose in your mouth...other end in the bowl...pull a suction, but be quick when you transfer the mouth end into the tub0 -
hand pump
I use this Silver King for injecting chemicals and inhibitor boosters into hydronic systems. It would drain a toilet trap also. I modified it for hydronic stuff with a hose connection end and insulation for hot boiler water. The ball valve is nice for quick shut off also.
I've heard firecrackers work also for emptying toilets
hot rod
bilge pump
I use a hand operated bilge pump, probally available at any boating/marine supply store. of course where I am, we have a boat yard/marina on every corner.
chuck shaw
i'm with DLO
i use a wolverine brass suction tool.their part # is 83500 and its about $20.00----i love mine, use it all the time. its really fun to close the bathroom door and see the funny look on people when you come out after they've been listening to this sucking sound emminating from the bathroom. its usually appropriate to burp about then, and smile.0 -
k.i.s.s - use a wet vac!0 -
K.I.S.S.
not on this site!!!!0 -
Plumbing sucks...
and so does the 2 gallon electric vacuum that I use. I can completely empty the tank AND the bowl, slick as a whistle in 2 minutes or less. I also use the vac for sucking the crap out of mechancial room floor drains, where the trap hasn't been taken out by some piece of unprotected condensing appliance.
We keep one set up for wet vaccing only on all of our trucks. You never know when you're going to have to solder a ball valve onto a leaking pipe. The water vac makes it possible, dry and simple.
ME
Plumbing sucks...
ME
i like to use my wet vac with
a supply tube ducted taped to it as a ''dentist type suction device'' slid thru a ball valve when the water wont shut off, so i can solder.0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
