Steam Radiators-Hugh McTernan
Hugh McTernan
Member Posts: 1
We are renovating a school built in 1924 with steam cast iron radiators for heating. Current temperature control is accomplished by a opening the window. The plan is to redo the system keeping the radiators. A person has suggested we convert to hot water. I like this idea since I believe it will be more efficient and easier to control with an energy management system. I am curious if anyone has done this before? and if there is info available on the output of old
steam radiators? Thanks.
E.D.R.
There's a book in the Books & More section that can help. It's called E.D.R.
There's also an article in the Hot Tech Topics area that gives tips on converting from steam to hot water.
You can also get some very good advice here if you'd like to keep the steam.Retired and loving it.0 -
Controling heating /conversion
If you would like to provide better control of the existing system, Thermostatic radiator vavles are available which allow every radiator to have its own thermostat. In addition, an outdoor temperature responsive control can be installed to help prevent tenants from abusing thier free heat", if spaces are rented. However, before doing all this, get the system if proper running order....Check for a contractor in the find a contractor section. If you are near Amboy, IL, send me an E-mail. I do agree that a water system can be more efficient and easily controlled and maintained, but at what cost? These same control methods are also avialable for hot water systems.
Boilerpro0
