drill/tap freedom flange for gauge....(j)
j_4
Member Posts: 59
anyone ever drill/tap freedom flange for gauge...the FPT threaded length seam to be enough to be able to tap a 1/8" Tee for a gauge on both sides of the pump.....
also, anyone know of a 6-way crossover valve to be able to pipe a differential gauge (two inlet ports) across both the pump & strainer & be able to selcet which p.d. to read...the 6-way swagelok only goes to 150deg F
What exactly...
is a 6 way sagelock? Is this anything like a four port henway?
Jist tryin' to help...
ME
So what's...
a four pound henway? Dan
Four pound henway???
I said four PORT henway.
You must have misunderstood my post :-)
ME
6-way swagelok
looks like this....gauge piped to the pair on the right & left....the upper 2 portd piped across the pump....the lower 2 ports piped across the strainer....0 -
and what is a 4 port henway?? pardon my ignorance0 -
A four port henway's
about 2 to 6 pounds depending on it's age and sex :-)
GOTCHA!!
Jeez, I was beginning to think that NOBODY would ask...
Jest in fun.
ME
Velly intellesting...
I can honestly say that in my nearly 30 years of roaming around boiler rooms that I've never come across one of these. Thanks j.
ME
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
