drill/tap freedom flange for gauge....(j)
j_4
j_4 Member Posts: 59
anyone ever drill/tap freedom flange for gauge...the FPT threaded length seam to be enough to be able to tap a 1/8" Tee for a gauge on both sides of the pump.....
also, anyone know of a 6-way crossover valve to be able to pipe a differential gauge (two inlet ports) across both the pump & strainer & be able to selcet which p.d. to read...the 6-way swagelok only goes to 150deg F
