slab manifolds - Molson
Molson
Member Posts: 6
I'm looking for a better method of installing my test manifolds prior to concrete pour. The objective here is to have the loops coming out of the concrete straight and neat.
Any suggestions???
Any suggestions???
NEAT AND TIDY
I have seen fella's sink a pipe standoff in the grade and strap the plastic u-bend to it so they are rigid. Also they will strap them in pairs with colored tape to denoted by red on top for supply and blue for return followed by color coded for 1-????.
Then drive two foot rebar through the steel and strap it.
Not going anywhere.
DVW0 -
CB
here is one I did. rather large house. installed rebar straight up, with a couple of cross braces, then mounted a piece of plywood to the rebar, and mounted the manifolds on the plywood.
the rebar, and plywood get removed after the house is built.
Manifold ideas
I have been toying with this idea for awhile. This manifold will allow 10 loops to come out of the slab and all fit in a 2X4 wall without crossing over each other. The 2-1/2 and 1-1/4 headers get capped.
To mount the manifolds I weld a short piece of unistrut to a piece of steel pipe. Drive them into the ground and fasten the manifold with a unistrut clamp. The pipe is easily cut off flush with the slab after the pour if you like.
I bend up some 12" long scrap pieces of pex al pex to build my own bend support/ tube protectors. 1/2" pex will slide thru 3/4" pex al pex easily.
hot rod
ways to hold manifold prior to walls
Call Roth at 401-267-9044, ask for Bill Bartlette or Matts Alstrom. They have ordered and are supposed to have recieved 10 mounts to do what you are looking for. I have only seen a prototype so ask for pictures :-)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
