HELP... looking for a boiler that will heat..........
David Sutton_2
David Sutton_2 Member Posts: 63
iam looking for a coil boiler that will heat 4- 120 gallon aqua bank water heaters the boiler will be one big coil heater to circ the water thru the coil then thru the aqua bank. the tanks are allready threre. just have to change the boiler. thank for your help ... David.... hi again , the set up is oil fired , they heat the same way as a aqua bank heats.m is for a school in conn.the heat load is 300,000btus, laars only has the gas i need it in oil thank you ....david
