Air-to-Water Heat Pumps in Cold Climates: What Should Homeowners Consider?
Air-to-water heat pumps are increasingly being considered for residential heating, particularly in homes with hydronic and radiant floor heating systems.
However, factors such as outdoor temperature, building insulation, water supply temperature, heat pump sizing, and backup heating can significantly affect overall system performance.
For professionals with experience installing air-to-water heat pumps in colder climates:
  • What supply water temperature provides the best balance between comfort and efficiency?
  • How important is buffer tank sizing in preventing short cycling?
  • When is a backup heating system necessary?
  • What are the most common installation mistakes?
I'd be interested in hearing practical experiences and recommendations from heating professionals.
