One zone still looks warm after the thermostats are satisfied
darine
I noticed one room was staying warmer than expected after the thermostats had stopped calling for heat.
I used a thermal camera to scan the accessible zone valves and nearby piping. Most of the zones had cooled down, but one valve and the pipe after it were still showing a warmer pattern.
That narrowed the problem from “why is the house still heating?” to one specific zone. I’m trying to work out whether I should start with the valve itself, the control wiring, or possible ghost flow.
Poll: What would you check first?
- Zone valve not closing fully
- End switch or relay still calling
- Ghost flow through the zone
- Circulator running longer than it should
- Need the piping and control details first
need more info, including brand and model
Living the hydronic dream0
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
