Plumber saves the day
ScottSecor
ScottSecor Posts: 1,090
In the news today, it appears that a plumber on an airplane may have saved the day.
https://www.nj.com/news/2026/11/frontier-flight-declares-mayday-after-bathroom-leak-floods-cabin-plumber-steps-in.html
    EBEBRATT-Ed Posts: 21,376
    I hope he was licensed in the air space he was in and took out a permit🤣🤣🤣🤣
    Jamie Hall Posts: 28,010
    That sort of thing is a good deal more serious than it sounds at first. In many aircraft — I'm not sure about the 320 neo, but in many other Airbus aircraft)— critical electronics (like the three computers which actually operate all the controls…) are below that area, and they do NOT like to get wet. Even a little bit wet. Boeings are a little more robust in that regard — but in general if those computers and switch banks get water in them, it is a real genuine emergency, and the folks in the front office are just hoping that there is enough backup to get them back on the ground in one piece.
    mattmia2 Posts: 18,453
    why isn't it potted with weatherpack connectors….
    Where it can be, it is. But — not all of it can be potted, because of cooling problems. And the real problems come in the high power contactors which transfer bus bar power around. They aren't exactly exposed — you can't go into the electronics bay and see the contacts — but they aren't waterproof, either.
