Spuds McKenzie and the Big Mouth
What’s the most practical way tighten these spuds? I ended up sticking my channel lock jaw in there to crank them down. There must be a better way. The traditional wrench is much too large.
We have cut man of those wrenched down in the past. Sometimes two inches, often more.
I've always cut them.
Does the spud have a hex female fitting?
If so a large allen wrench might do it.
Or a long bolt with 2 nuts set up jammed against each other. Then wrench or socket on the jam nuts.
5/8" hex/allen wrench
I believe it is a 5/8" hex (at least for the 3/4" pipe version), easy if you have the correct tools.
One Pipe System0 -
With that positioning you are going to loose more water. I think the OEM wants them vertical for the main venting application.
One Pipe System0 -
@GW Some do take a hex like a big Allen wrench. What I have done removing old steam traps and radiator valve spuds (if I have a lot of them to do) Is get some square stock and grind it to fit whatever it needs to fit and wrench on it with an adjustable wrench.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
