Spuds McKenzie and the Big Mouth
GW
GW Posts: 5,275
What’s the most practical way tighten these spuds? I ended up sticking my channel lock jaw in there to crank them down. There must be a better way. The traditional wrench is much too large.
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • ScottSecor
    ScottSecor Posts: 1,087
    We have cut man of those wrenched down in the past. Sometimes two inches, often more.
    mattmia2 Posts: 18,443
    screw them in to the tee, then screw the tee on?
    internal pipe wrench? chain wrench?
    bjohnhy
  • Grallert
    Grallert Posts: 1,251
    I've always cut them.
  • JUGHNE
    JUGHNE Posts: 11,660
    Does the spud have a hex female fitting?
    If so a large allen wrench might do it.
    Or a long bolt with 2 nuts set up jammed against each other. Then wrench or socket on the jam nuts.
  • ScottSecor
    I have also used a hex steel chisel, roughly 1/2" diameter for less than one inch tailpieces, and roughly 1" diameter for 1" and larger tailpieces. I grabbed the chisel with an adjustable wrench and the tailpiece with a pipe wrench or Channellocks.
  • ChrisJ
    ChrisJ Posts: 17,779
    You need to be careful using names like that.
    When a 35 year old with multiple kids says "who?!?" you're going to need a few Advil and a chair.
    mattmia2kcopp
  • STEAM DOCTOR
    STEAM DOCTOR Posts: 2,681
    5/8" hex/allen wrench
    109A_5 Posts: 4,786
    I believe it is a 5/8" hex (at least for the 3/4" pipe version), easy if you have the correct tools.
    109A_5 Posts: 4,786
    With that positioning you are going to loose more water. I think the OEM wants them vertical for the main venting application.
    EBEBRATT-Ed Posts: 21,370
    @GW Some do take a hex like a big Allen wrench. What I have done removing old steam traps and radiator valve spuds (if I have a lot of them to do) Is get some square stock and grind it to fit whatever it needs to fit and wrench on it with an adjustable wrench.
